Question Mid tower ATX case
May 6, 2022
I’m relatively new to the PC building scene, but I’m looking for something similar to the Lian Li O11 Dynamic Evo case that fits an ATX Board and its cable management segment, but I need a similar case that can fit a 360mm radiator on the top of the case but can also fit, x3 120mm fans on the front and side…
Phantek's ripped off the same case design under their MetallicGear branding, and if you go down the same rabbit hole you'll see other brands who have ripped off the same design language used by Lian-Li. You might want to stick to getting something with a Lian-Li bagde, since you'll be paying for quality.
