Mind f...kd! need help!
dzenn
11
so heres my question:
is your operating sysem in you RAM after you boot it?
where is it after you boot it?
Can you please explain it clearly,cause its really bugging me. 🙁
is it like a program,w/c is from HDD and stored in RAM so that the CPU can access it quickly?
or its like a one time loading operation,w/c is from HDD directly to the CPU because its only an "environment" and you dont need to process it quickly because you pretty much dont edit its registries?
I know that programs is first loaded to your RAM after it gets it from the HDD,so that your CPU can process it faster.
I also know that program is also called application software,w/c is pretty much a "software" like an operating system.
i also wanna say more things than this but i just wanna stick to my question.i hope that you can help me
if it is in the RAM,then why also is it so small you can barely see its size?
Thank you :hello:
The story was last updated in July 2000 : )
But its correct, as far as I can tell. In detail!
