Minecraft cpu Problem
kyle_60
Commendable
Apr 4, 2016
5
So when I'm playing modded Minecraft I have really bad CPU 100% of it is being used and this concerns me will it blow up I don't know as I am 13 i play on the rr3 pack on At launcher i play on a server called mod realms
Again, modded MC is much different than normal MC.
For example, nearly every pack out there uses the multicore version of Optifine which offloads the chunk loading to multiple cores.
In addition, some programs report CPU usage, but not on a per core basis. Task manager is one such program.
All of the newer versions of optifine dont have the multi core option from what i know sadly.
And yes i know that i have lots of modding experience in minecraft. I modified SEUS shader code and made it look amazing with some parallax textures and my fps tanked lol
Minecraft sadly only uses 1 CPU core (which it should use 2+, it'd make render distance drop less frames), anyway some mods do use more than 1, so if you'll tell us if you modded it or not, then we can tell you if it's normal or not. And CPUs don't blow up, it'd be cool, but it doesn't happen 😛
