photonboy :
Unolocogringo :
Most laptop problems are caused by overheating.
When was the last time the heatsinks on the inside were cleaned.
Never
http://www.youtube.com/watch?v=deP-DdB_NXE
I already did that. I'm not sure if i need forge but i can't get forge because everytime i download it i get
I still think it's a software issue. No idea if the above link is relevant.
Again, the BEST troubleshooting method is to run that Torchlight DEMO. If the frame rate doesn't drop your issue is specific to Minecraft.
I already did that. I think i need forge, but i tried downloading 7 times and i get the same error everytime. I get 100 FPS. I don't think that will help me. The problem is the FPS drops after 5 minutes. By the way i got cracked (i will pay minecraft until my laptop can actually run minecraft properly). Oh and i can play Leauge Of Legends on all low settings without as much lag as minecraft. I don't think i should download the game you told me.
I don't quite understand what you're saying.
1) You can't download the demo? I had no problems.
2) Why don't you think this will help?
3) You can play League of Legends fine? What frame rate do you stabilize at?
4) What do you mean by "lag" in League of Legends.
*Basically, all you need to do is run a different game to see if you can without your frame rate dropping to nothing. If you can, then your issue isn't HARDWARE. It's an issue with Minecraft itself.
And please don't admit to pirating a game (I think that's what you meant) even if you intend to buy it later. That sort of thing is not tolerated here.
