---- Minecraft Crash Report ----
// Hi. I'm Minecraft, and I'm a crashaholic.
Time: 06/08/19 22:36
Description: Initializing game
java.lang.IllegalStateException: GLFW error 65542: WGL: The driver does not appear to support OpenGL
at cuo.b(SourceFile:199)
at org.lwjgl.glfw.GLFWErrorCallbackI.callback(GLFWErrorCallbackI.java:36)
at org.lwjgl.system.JNI.invokePPPP(Native Method)
at org.lwjgl.glfw.GLFW.nglfwCreateWindow(GLFW.java:1714)
at org.lwjgl.glfw.GLFW.glfwCreateWindow(GLFW.java:1897)
at cuo.<init>(SourceFile:81)
at dnr.a(SourceFile:19)
at cyc.au(SourceFile:464)
at cyc.b(SourceFile:394)
at net.minecraft.client.main.Main.main(SourceFile:155)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.14.4
Minecraft Version ID: 1.14.4
Operating System: Windows 10 (amd64) version 10.0
Java Version: 1.8.0_221, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 189468056 bytes (180 MB) / 330956800 bytes (315 MB) up to 1060372480 bytes (1011 MB)
CPUs: 4
JVM Flags: 6 total; -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump
Launched Version: 1.14.4
LWJGL: 3.2.2 build 10
OpenGL: NO CONTEXT
GL Caps:
Using VBOs: Yes
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language:ERROR NullPointerException: null
CPU: <unknown>
#@!@# Game crashed! Crash report saved to: #@!@# C:\Users\glend\AppData\Roaming\.minecraft\crash-reports\crash-2019-08-06_22.36.42-client.txt
Java HotSpot(TM) 64-Bit Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
CPUs: 4
OpenGL: NO CONTEXT
GL Caps:
Using VBOs: Yes
Resource Packs:
Current Language:
CPU: <unknown>
