Mini DV: Upper or Lower field first?
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
What is the default field order for exporting clips in the MS DV AVI
format? Does it make a difference
if it's upper or lower field first?
Thanks
DV is Lower Field First, so I'd stick with that.
-WD
>Thanks
It makes a difference. DV is supposed to be lower field first, but some
capture programs do not label things correctly, and some clips get their fields
reversed due to glitches in the source material.
So.
Best idea is to set up your procedure and test it both ways.
Does this apply to PAL as well as NTSC? I thought PAL used upper field but I
could be wrong?
"Will Dormann" <wdormann@yahoo.com.invalid> wrote in message
news:sx%wc.49678$DG4.33350@fe2.columbus.rr.com...
> -WD
PAL was upper field in most analogue systems, but redefined to lower
field first for DV (caused me no end of confusion when I first got a
DV edit system, kept trying to force it to upper field 🙂
Cheers
>could be wrong?
>> -WD
Kevin Gleeson
Blue Rocket Productions
www.blue-rocket.com.au
www.hoota-snoz.com
