Mini Fridge/Freezer Cooled PC
Nigh
152
Alright, you guys may have heard of such a novel idea before, and I did some research that showed why it won't work, and some rigs that apparently do, and my question is: How would one go about making a mini fridge/freezer cooled PC? The first thing that came to mind is that whenever I opened my freezer, a little mist came out. This is not good, as the mist could condense on my parts and wreck my PC. Would this happen always? Is there a way to avoid it? That and also would it be possible to keep the fridge running always, overriding the phase change cycle's stop and go, so that it would provide constant cooling? If there was a way to constantly cool a PC with a mini freezer, and not have a component destroying mist, my idea is to take a Thermaltake Armor A10, rip it apart, screw in the panels inside the freezer, open up the freezer, and reroute the wires and pipes so that there would be holes in the back and front for all the ports to surface, and then install the components as with any other PC case. The main reason I'd want to do this is for heavy-massive overclocking so I'd have enough cooling. Any help, suggestions and/or cautions? Thanks!
Jesus, kids, chill. Nothing is impossible... 😀
Back in the days of glorious Pentiums we used to experiment with old parts. And we did many things - custom coolers out of engine pumps and we even build our computers inside a fridge. /well. agreed, they were only...
Simple physics:
Any component that is cooled below the dew point of surrounding air will result in condensation. This means that when you open the door and you get "room" air flow into, fridge, or around components you will have condensation.
We often do temperature cycle test on equipment. Ie cool down to say 10 C, allow to come back upto say 20 C and power on. Also do this on hot cycles. When test is done, or if door is to be opened, the rule is you heat the system up to above ambient and let it soak for a couple of hours then it is safe to open door.
This has been brought up a couple of times in the past and I do NOT think anyone came up with a good method of using a fridge.
it won't work. fridges use insulation and a small cooling loop, and probably could cool off 10W-25W of heat energy per minute. They aren't made to continuously cool a 100W cpu. you'd burn out the motor... if anything it would be a wonderful HOTBOX, because the insulation and lack of airflow and the inadequate cooling would result in the insides of the fridge would superheat.
the best you could do is maybe make some sort of heat exchange unit by taking the coil off the fridge and wrapping some sort of copper piping around it, then using that to cool a water system... but even then i doubt it could cool the water more effectively then a fan and a heatsink; and you'd still probably burn out the motor since it isn't made for continual use.
Interesting.
I guess it's possible to do it that way. Make sure the fridge/freezer is airtight after you have modded it and stick a whole bunch of silica gel in to absorb the moisture in the air. I don't think the cooling power will be sufficient though. Should be looking into something more on the industrial side of the scale like an ice cream vending freezer.
Fridges, large or small, are not made for a constant ON cycle. In this situation, the PC is continuously pumping heat into the system.
It can't keep up and will die.
Back in the days of glorious Pentiums we used to experiment with old parts. And we did many things - custom coolers out of engine pumps and we even build our computers inside a fridge. /well. agreed, they were only ~50W TDP processors, but it was possible.../
The only problem was, as correctly stated above, condensation.
We tried many ways - antistatic airtight bags for HDD /which sucked/, sprayed mobo with non-conductive paint /not a good idea either/ and finally took all cables out through a small cut through the front door and duct-taped the thing airtight close... Well it was fun and the machine worked. And you could overclock it fairly well at standard settings /5oC/.
Now that I think of it... Too bad we didn't tried freezing mode to cool the insides below 0oC... Or tweaked the cooling system a bit...
Or... Oh well... Maybe I try to build another fridge computer out of spare parts someday...
Bottom line - If you have any spare parts left - go for it. It's a nice past time 😀
People have used all kinds of things as heat exchangers. Car and motorcycle radiators, for instance. As a passive medium with fans blowing air through it, sure.
Using the fridge innards as active cooling, not so much.
Yeah, I'll probably try it with lower end parts and overclock from there if the build is stable. It's probably going to be a project for next summer, as my very first build will be this summer, and I plan to do a LOT more research into this topic and see if it would be possible to mod the fridge to be able to give the cooling power I'd need. Someone brought up bragging rights, that's spot on with what I plan to do, but I need it to be stable before showing anyone, lest I be showing a mini fridge with melted innards. Thanks for all the input though, when I do the rig I'll post the results. You'll probably forget this by then, by why not?
Your approach is a good idea and bad idea... is it possible? Not with just the fridge alone... first calculate the amount of cubic space a fridge can cool... without a heat source inside... its impractical...
However just to kick up some condensation on this thread over 4 years old, here's a solution... first off you wouldn't do anything crazy like that to save money, but heres a way to do it for half the price of a custom water loop and is mildly economical!!!
Items needed - used gun display case (large glass 3 window and metal back), window silicon, duct tape, cheap atx tower, all your cpu parts and of course the cooling aparatus will be a 3 in 1 floor air conditioner with remote. also note you'll need other materials for a furnace duct system to direct air or acrylic sheeting. Get creative with it.
Why a gun display case? Its easy to seal with silicon...
The most important part aside from pc and case is the cooling apparatus. The 3 in 1 comes with a dehumidifier. You will want to run a drain hose out of the gun display case from it into a bucket at least. So why a 3 in 1 floor ac unit? Its all about the squarefootage baby! Lets say gun display is 3'x3'x6'=54 cubic feet. A 3 in 1 rated for 300 squarefeet, which rated for a standard 8' ceiling... so 10'x30'x8=2400 cubic feet to be cooled against high watt devices like tv's, fridges, deep freezer, gaming consoles, pc's (wink). It gets better! The 3 in 1 also comes with a large sp fan that is filtered!
So on your 3 in 1 you have 3 air ports. Heat exhaust, filtered intake (both on back) and cold exhaust on front. Luckily the 3 in 1 comes with a heat exhaust extension that installs in any house window.
Build it how ever you like but here is the technical break down. After installing everything, seal the door with tape and use the remote to power on the 3 in 1 in dehumidifier mode. Wait awhile and check humidity, once humidity lowers below 30 then its safe to switch to cool which will also dehumidify the air further. With the cooling exhaust blasting on the cut up tower to optimize air on it with it jammed inside a duct vent that is mounted and supported to cooling exhaust. Watch your temp probes and enjoy... you got a ton of space in that case to get really creative! Like turn a old acrylic aquarium into cpu case... i left out a lot of the creative stuff, but hey its your design, your money, your baby and you can control the humidity levels as well as temp via remote... but at least it will work! i also don't reccomend dropping the case temp to low, about 60 degree's inside case and 70 degree's inside room... you'll get condensation on outside and have to keep drying it unless you dehumidify the room the setup is in. To optimize it, install liquid cooled radiators for gpu's and cpu, just run the radiators behind the 3 in 1 filtered intake to cool heat. I would reccomend a insultator and custom mount plate. Be just like server cooled warehouse...
Also for a fridge build, let me know if you see any old cake display fridges like they have in old style diners that broken. i got crazy idea for a pc build involving one. note the fridge part is useless and bleep the cake, i got another party in mind. A mad scientist party!
