Mini Itx Aftermarket CPU Cooler
Change_Later
Commendable
Feb 8, 2017
27
In the near future I will be building a pc in the Phanteks Enthoo Evolv Mini-ITX case. Although the CPU I will be using cannot be overclocked, the i5 7400, I still want to get an after market CPU cooler for future proof (and because it looks cool). My question is what CPU cooler should I use?
Also the motherboard I will be using is the ASUS STRIX B250i (if that helps in anyway).
You can get the Cryorig H7, its a good quality cooler. But one thing if you are looking to upgrade in the future, then i5 8400 is a better choice; Anyways you wont go wrong with either of it.
