Mini ITX build - first PC build
jwdixo01
I'm putting together a PC for casual gaming (wanting to get back into WOW but also want okay hardware to play others if I so wish). The smaller the better, it doesn't have to be an ATX cube case but it certainly is appealing and would be more convenient. I have a list compiled on Amazon ready to order. I was wondering if someone could take a look at the parts and make sure they're compatible with one another and will fit in the smaller case. If you see ways I can save money let me know too. I'm a first time PC builder and need all the help I can get. Thanks.
Thermaltake Core V1 Snow Edition Extreme Mini ITX Cube Chassis Cases CA-1B8-00S6WN-01, White https://www.amazon.com/dp/B015UDUAKG/ref=cm_sw_r_cp_awd_wW8Fwb6QR4SB1
AMD FD6300WMHKBOX FX-6300 6-Core Processor Black Edition https://www.amazon.com/dp/B009O7YORK/ref=cm_sw_r_cp_awd_ZX8FwbT6ZHN8T
Cooler Master GM Series G650M - Compact 650W 80 PLUS Bronze Modular PSU (6th Generation Skylake Support) https://www.amazon.com/dp/B00MAZK6IO/ref=cm_sw_r_cp_awd_mY8FwbKXX0TPT
Gigabyte AMD R9 380 256 Bit GDDR5 4GB 2xDVI/HDMI/DP G1 Gaming Graphics Card GV-R938G1 GAMING-4GD https://www.amazon.com/dp/B00ZGF3TUC/ref=cm_sw_r_cp_awd_PY8Fwb72K20TS
Cooler Master Hyper TX3 - CPU Cooler with 3 Direct Contact Heat Pipes (RR-910-HTX3-G1) https://www.amazon.com/dp/B0028Y4S9K/ref=cm_sw_r_cp_awd_dZ8FwbYJJ4R8B
Corsair XMS3 8GB (2x4GB) DDR3 1600 MHz (PC3 12800) Desktop Memory (CMX8GX3M2A1600C9) https://www.amazon.com/dp/B0042A7CAA/ref=cm_sw_r_cp_awd_IZ8FwbWFRPMEF
ASUS Micro ATX DDR3 2000 AMD AM3+ Motherboard M5A78L-M/USB3 https://www.amazon.com/dp/B00DQO9L1Q/ref=cm_sw_r_cp_awd_j08FwbW1BH6Y9
I need a hard drive obviously, do I need an SSD with this case? Any suggestions on hard drive appreciated. Thanks!
Latest posts
