Hi,
So I'm making my mini ITX gaming PC. This will be my first build in 8 years. I need help with the configurations.
This is what I'm building.
CPU i5 6402P
MOBO Z170i or H170i or H110
GPU GTX 1060 or GTX 970
RAM 8 GB DDR4
HDD 1 TB + 120 SSD
PSU 650V
CABINET CM Elite 130
Or any other suggestions for full sized GPU? I like this one (https://goo.gl/j5crvR) but the seller says that the maximum GPU it can fit is 7.5in long x 3.15in high. Also in India it's difficult to find mini ITX cases, so I'm having a hard time trying to find the cases except the Cooler Master
MOBO
Which one should I choose? Though I'm having a hard time trying to find H110 in mini ITX form online on Indian websites. But I guess it's really cheap compared to the other two. I'm going to use a single GPU. Which one should I go for?
GPU
Because Cooler Master takes in a full sized GPU I don't have to worry about the size. Only if I opt for some other case will I need to search for Mini ITX GPUs of which GTX 1060 is easily available. Prices are almost similar. Which one would be better for my build? or can I use a cheaper one if there is any which can play most of the demanding games.
Cooling
Do I require additional cooling or liquid cooling? If so, which one would suffice?
Any other suggestions? Mentioning the budget will be a bit difficult as the US and Indian prices are different for the product but this is the rough working.
In INR my budget is around Rs.65000 - Rs.70000 which is $975 - $1012 but effectively it will be around $750 - $800 if you build it in USA.
CPU i5 6402P
RAM 8 GB DDR4
HDD 1 TB + 120 SSD
PSU 650V
MOBO
GPU
Cooling
