Mini-ITX Gaming/Video editing/multimedia PC [Final Build Help]
Trippy_8bit
5
Hi there!
I've decided to join the so called PC master race, so I need your help/feedback. My budget is maxed out, after a month of research I threw together this (hopefully) final list, based on my needs. I decided to go with the Intel/Nvidia combo, and the Mini-ITX size simply due to the fact that I want to keep the PC off the ground/on my desk. I have animals around all the time.
The purpose of this machine will be following:
Oldschool/next-gen gaming, possibly GTA V when it's released,
Light to medium video editing/motion graphics mostly in 720p,
Heavy, daily video streaming.
The build: http://pcpartpicker.com/user/Trippy8bit/saved/dRCZxr
The CPU cooler which I really like does not show up on pcpartpickers' list, but it's a Thermaltake NIC F3
http://www.thermaltake.com/products-model.aspx?id=C_00002026
If this doesn't fit in the case, please suggest another with similar price range.
Why I post this whole thing?
I just want confirmation from people who have way more experience in the field than I do. If you say it's a solid build, then I hit the order button.
I'm not a hardcore gamer, or a professional video editor, I just like to try new things here and there, I want a future proof build, that'll last for 4-5 years, that's all. Anyways...
Many thanks in advance for your feedback!
some parts you are overpaying and PSU is not of high quality with adjustments you can get an i5 CPU i would possibly also wait for gtx 960 to be released before buying a video card or just buy everything and use onboard video card until they release the 960.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($179.99 @ NCIX US)
Motherboard: ASRock H81M-ITX Mini ITX LGA1150 Motherboard ($64.98 @ SuperBiiz)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-1600 Memory ($69.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($53.98 @ OutletPC)
Video Card: Asus GeForce GTX 760 2GB DirectCU II Video Card ($205.66 @ Newegg)
Case: BitFenix Prodigy (White) Mini ITX Tower Case ($68.99 @ NCIX US)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($54.99 @ NCIX US)
Total: $698.58
Generated by PCPartPicker 2014-09-22 17:04 EDT-0400
