Hi,
I'm a not-so-experienced builder - I have only built one PC before and it came as a kit with some parts already assembled -- the mobo and PSU were already installed.
I do have a modern Win10 pc that someone else built.
As partly an experiment and partly for actual use, I'd like to make a new build for Win XP 64-bit. I'm loving the small form factor / miniITX setup - I like the compactness (even if it limits things a bit).
Well, as a not-so-experienced builder, I'm not too knowledgeable on "what is compatible with what". I can take a guess that certain components purchased nowadays, would no longer be compatible with Win XP. I am pretty sure that motherboards are one of these things, and I know for sure that video cards are another one.
So my criteria would be:
1.) Everything needs to be able to work with XP
2.) Small form factor build
3.) Probably OK to run games that are around ~2013 games and older? I don't care too much about super brand new games, and they probably require DX10+ anyways, and I know that XP stops at DX9. Need to be probably OK to do some video editing, PhotoShop, 3D modeling. Just remember that since it's XP, I used older versions of these things, which aren't as cpu-intensive!
4.) Not insanely expensive, but I don't imagine this build could be too expensive anyways? Would like to keep it below 450$-500$.
5.) Don't really need a motherboard with lots of extra built-in stuff like wi-fi/blutooth, only really want 1 video card slot.
6.) Would prefer VGA output.
This is what I picked so far, but again, I'm not experienced. A friend said he preferred AMD so I went with that in mind, but it's not a requirement.
https://pcpartpicker.com/list/4n7Yhq
My question would be is this fine, considering what I'm going for? Will this all work with XP, and are there any glaring bottlenecks or parts I should definitely swap out? I should also mention I already have the video card in that part list, and it has drivers for XP. However, I am not 100% sure if this video card would be fine enough for 4+ year old games and older, but, I hope that it would be.
Thanks for any advice
