MINI PCI WIRELESS card bcm 4306 sagem ets
yanko54
Hi, i have the problem - can`t find the driver for the wi-fi mini pci card S/N 06UT41031577 , after a virus attack ant pre install of OS WinXPsp2 on Elitegroup ECS532 laptop I seized to have wi-fi internet.
Hlp, pls
yan
Thank you Emerald.
Obviously I really must perform a clean install of the OS, because during the repair process something went wrong, due to my decision to delete Windows folder and recopy the files needed in the same location \ I`ve successfully performed this in win98/
Really I did a mess!
I produces two administrator`s folders, doubled the all user folder and etc. and finally found out the wireless problem after brave and unaccountable action of reducing the files and the folders=
Now I have a set of files that seems normal, the OS works fine, the cable internet work, but the wi-fi card is named "Dell TrueMobile 1300 WLAN Mini-PCI Card" instead of "mini PCI WIRELESS card bcm 4306 sagem ets", windows can`t configure the network settings and works hard...
oh...
as I find to use these drivers i must have Ralink card....
Regards
Yan
yanko54@abv.bg
