hi
Dont ask me my budget it is the smallest possible . Im not ready to buy a gpu to play link BUT i would like to buy the moste affordable setup or at least not expensive that would allow me to add a normal size gpu to play link occulus .
Note: i already have ssd+fans + cas + psu
the minimum to roll occulus like is the i5 4590 8g ram. i prefer to invest on gpu instead of the rest of the system apparantly that is what mek the difference.
i could buy this pc below but correct me if im wrong but the below is not atx so it is not possible to add a gpu normal price( i heard the gpu for small mobo are more expensive for the same performance is that true?)
149 canadian dollar : Dell Optiplex 3020 SFF Desktop Core i5-4590 3.3 Ghz 8GB RAM 500GB HDD Win10 Warr
https://www.ebay.com/itm/Dell-Optip...314481?hash=item56defd1171:g:GNIAAOSwiR9fBfQx
choice A 349 dollar canadian
yes i could buy NEW for ryzen 3 3100 +msi b450 gamin plus mobo + vengeance corsaire flx 16 g ddr4 3200 cl16
Choice b 209 canadian dollar
a USED BUNDLE MSI H97 PC MATE Motherboard, Corsair 16GB Ram, Intel Core i5 - 4590 CPU
Choice CWell maybe something used in between those 2 in terms of price and performance. do you have sugestion from ebay for example?
Also im interested in knowing what is you opion advantage disadvantage of each choice ,
wich would you choose and why.
so far i m aware that buying new give me some guaranty with visa
And ddr4 is faster that ddr3.
what to consider ?
tx
what to consider ?
tx
