Hi Guys,
I'm putting together my first PC and as luck would have it, I got a Corsair VS650 650W PSU that came with a UK plug (rectangularish prongs as opposed to the roundish ones we use in India). The seller says all his PSUs have the same problem. He offered me a replacement power cable which claims to support up to 10A (ampere).
The sticker attached to the original Corsair power cable clearly says 13A power plug needed (if the original has to be removed for any reason). Now I thought I'd look around and find a power cable that matches 13A (and say no to the seller's solution). Unfortunately I can't find a power cable rated above 10A.
Will it be safe to run my PC on a 10A cable ? My rig will be -
AMD FX 8320/Intel i5 4460
Nvidia GTX 960
Corsair Vengeance 8GB RAM
standard HDD and Optical Drive
An alternative seems to be a power adapter that transforms the UK plug into an Indian plug. But I've heard they are often not dependable when used over extended periods of time.
I don't want to end up buying another PSU! Any help would be deeply appreciated!
Nvidia GTX 960
