Quite the opposite actually. You can mine with the same hashrate on low end cpus vs a high end i7 or ryzen. Cpu usage is very little and runs just about only the os. You'll see most getting/suggesting low end pentiums for lower power usage. Others are using older hardware (althons, core 2, apus, whatever) they already had but they tend to be higher power usage. Whatever gets them the best value. They get the same hashrates as long as the cpu isn't a potato struggling to run windows. It's just easier to get a pc running gpus than it is to get a rasp pi to do the same.
