Question miniUSB to 3-pin + satapower = cable powering Antec M240 AIO Cooler's pump
Apr 13, 2019
Hello.
I have Antec M240 and I need a replacement cable to power the pump. I need help understanding this cable design, because I can't find anything like that. Would the pump work with miniUSB to USBfemale to USB to satapower? Or does anyone have an idea how can I power the pump without the original cable? I can't find USB to sata + 3-pin.
Thank you for your help.
From the website photos it appears the power cables for this system all start from a SATA power output from a PSU. You can NOT get that kind of power from a USB port. So forget about trying to use USN anything. Moreover, although the connector MAY look like a USB of some sort, it really is a custom design. So even if you could get a mini USB connector to fit, the wiring connections need to be made correctly. Try contacting Antec Tech Support for a source of the RIGHT cable.
