Purchased a Minix Z83-4 mini PC. Was having issues with BSOD and thought maybe it had a flawed install of Windows 10. When I hooked it up in my office to a 27" monitor via HDMI it worked fine. Had great picture and sound through the monitor's speakers. But when I moved it to my home theater and hooked up through my AVR to run my media library on network, I was getting BSOD. I tried to reset it back to factory and had no luck there. I then returned it to the seller and got another. Had the same thing happen. Worked fine in the office hooked up to the Asus monitor, but got BSODs when hooked up to AVR. Tried using different HDMI cables, different CAT5 cable, still with no luck. I then did a complete reinstall of windows using a USB stick. Again, worked fine on the monitor but for some reason when hooked up to the AVR this time, was working ok but now I had no sound device found. I tried loading audio driver only to have them not work and after reboot, still no audio device found. Shortly thereafter the BSOD's started again.
Took the thing back into my office to try to troubleshoot next to my main PC, hooked it up, and voila... worked perfectly. Even watched an entire movie from the library hosted on the main PC with no issues at all.
So here is my grand dilemma. i am pretty sure that the issue is being caused by the AVR. The Mini PC is hooked up via HDMI on my Marantz SR7001. I get a great picture on the TV (LG 60" 1080p), but still no sound device is found. Any thoughts or ideas what might be causing the issue and what might be a solution?
