Mirrrors Edge freezing
did007
24
I have just installed "mirrors edge" in my pc. but playing it for sometimes it began to freez and nothing happens. i updated my games with the latest patch. i had change it compatibility with all possibilities. but the problem remains! please help me out guys.
my pc configuration:
core i5 75o running @2.66ghz
mother board gigabyte ga-p55-usb3
4gb corssair ,
two 500gb wd hdd,
windows 7x64
psu: cooler master extreme power plus 600watt
2days ago
Well we can rule out a dusty rig. Your PSU is not the best one out there and it is on the do not buy list. So I take it you are not checking your temps? So I will link you to the free programs to test your rig.
The things I will link you to are MSI Afterburner with it's user manual. Core temps, gpu-z, HW monitor, etc. Onece you have ruled out the temps then we start looking at the PSU or even your GPU. By the way what is your GPU?
http://event.msi.com/vga/afterburner/download.htm
http://event.msi.com/vga/afterburner/images/Afterburner%20User%20Manual.pdf
http://www.cpuid.com/softwares/hwmonitor.html
http://www.techpowerup.com/realtemp/
http://www.techpowerup.com/gpuz/
http://www.alcpu.com/CoreTemp/
http://www.ozone3d.net/msi_kombustor/
xfx gts 250 1gb ddr3
