Missile Command VGA replacement display OK?
G
Guest
Guest
Hello,
My 1980 Missile Command upright monitor died. Would it work to connect the MC's 6 pins (R,G,B, GND, H-Sync, V-Sync)into the corresponding input pins of a VGA monitor's standard connector using only a (custom) adapter cable?
about the missile command arcade cable to vga monitor is there anysolution for this?
I opened this thread just today....
Hello I'm really excited to finally find a Forum like this one. Hope you guys can help me on this one.
currently I own a Missile Command upright machine I've had it since 1992 but for one reason or another I haven't been able to make it work for more than a cople of weeks.
In the beggining I had a bad Motherboard But luckily I found one on ebay. it worked fine until my monitor died on me a couple of weeks after.
recently I bought an adapter:
http://cgi.ebay.com/CGA-EGA-YUV-VGA-converter-2-VGA-output-arcade-game-/260621719104?pt=Video_Games&hash=item3cae43d640
but I was unable to make it work. (Missile Command on VGA Monitor).
do any of you guys know where I can find a monitor or a special cable to help me on this problem.
thanks for any help.
