Missing 8th pin on 24 pin connector
nwolf1010
52
Could a missing 8th pin on a 24 pin connector from the psu cause a PC to start then run off again after less then a second?
Hard to tell what you mean by "8th pin" ... 8th pin from what starting point
https://www.lifewire.com/atx-24-pin-12v-power-supply-pinout-2624578
8 PWR_ON Gray Power Good
Are you sure then pin just didn't pop out of the connector ? is this a modular cable which can be replaced ?
You can repair the connector using tools and pins / cables whatever which can be purchased at locations such as frozencpu.com
http://www.frozencpu.com/products/3835/too-05/Dual_Ended_Universal_Molex_Removal_Tool.html
http://www.frozencpu.com/cat/l3/g51/c393/s2099/list/p1/Connectors-Connector_Pins-Molex_Pins-Page1.html
You will need a soldering iron and heat shrink also
All the above parts are universal and will work on all PSUs.
nwolf1010
52
PCPartPicker part list: https://pcpartpicker.com/list/yKtJKZ
Price breakdown by merchant: https://pcpartpicker.com/list/yKtJKZ/by_merchant/
CPU: Intel - Core i5-7500 3.4GHz Quad-Core Processor ($197.68 @ OutletPC)
Motherboard: Gigabyte - GA-B250M-D3H Micro ATX LGA1151 Motherboard ($79.99 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory ($145.99 @ Newegg)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($66.89 @ OutletPC)
Video Card: NVIDIA - GeForce GTX 1080 8GB Founders Edition Video Card ($549.99 @ Best Buy)
Case: Corsair - Air 240 MicroATX Mid Tower Case ($79.99 @ Newegg)
Power Supply: EVGA - 500W 80+ Bronze Certified ATX Power Supply ($45.77 @ OutletPC)
Wireless Network Adapter: TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter ($17.49 @ OutletPC)
Case Fan: Corsair - HD120 RGB 54.4 CFM 120mm Fan ($26.61 @ OutletPC)
Monitor: AOC - G2460VQ6 24.0" 1920x1080 75Hz Monitor ($149.98 @ B&H)
Keyboard: Corsair - K95 RGB PLATINUM Wired Gaming Keyboard ($199.99 @ Amazon)
Mouse: SteelSeries - Rival 300 Wired Optical Mouse ($49.99 @ Best Buy)
Total: $1610.36
Generated by PCPartPicker 2017-09-07 13:12 EDT-0400
As above 3 options;
1. Are you sure then pin just didn't pop out of the connector ? Solution: Pop it back in
2. Is this a modular cable which can be replaced ? Solution: replace
3. You can repair the connector using tools and pins / cables whatever which can be purchased at locations such as frozencpu.com
http://www.frozencpu.com/products/3835/too-05/Dual_Ende...
http://www.frozencpu.com/cat/l3/g51/c393/s2099/list/p1/...
If the pin and cable is missing entirely, RMA is the only option assuming again, not modular
EDIT: The B1 is nit modular
