Missing audio when using conversion from DisplayPort to HDMI
bobBuilder9
Commendable
Mar 14, 2016
I am connecting my desktop pc (equipped with DisplayPort and DVI-A) to my Sony Bravia TV using a DisplayPort-to-HDMI cable.
Prblem is, the audio is missing. When I am in audio/settings, the digital HDMI cannot be configures as it appears not to be plugged in, and I only have the choice of the speakers.
Video works fine.
My pc is a Dell win 10 (upgraded from 7) and all drivers are up to date.
Any idea?
For what I can see there, you don't have the audio drivers installed, you have the generic HD audio device driver that comes with Windows. But that shouldn't be an issue because those drivers are separate from the graphics card audio output.
But still, you should install them. Here's the link for the integrated motherboard's audio from the Realtek website:
http://12244.wpc.azureedge.net/8012244/drivers/rtdrivers/pc/audio/0006-64bit_Win7_Win8_Win81_Win10_R279.exe
Or go to this link and select the 64 bit version: http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
Regarding audio over the Display Port output, I think you won't be able to do it with Windows 10...
It could be one of the following:
1. The selected default sound device is not your Display Port output (Check this right clicking on the computer speaker next to the clock and then "Playback devices".
2. Your adapter doesn't support audio
3. Your video output is from the integrated graphics adapter and does not necessarily carry an audio signal too
4. The audio drivers for your graphics adapter are not installed.
Could you give us more information regarding your computer model and specs?
1. is not an option, as I the DisplayPort output option is not listed, and the TV appears as "not plugged in".
About my pc, here is the firs part of the DxDiag:
System Information
Time of this report: 3/14/2016, 22:02:38
Operating System: Windows 10 Pro 64-bit (10.0, Build 10586)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: OptiPlex 980
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A02
Processor: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz (4 CPUs), ~3.2GHz
Memory: 8192MB RAM
Available OS Memory: 8182MB RAM
Page File: 6033MB used, 10340MB available
Windows Dir: C:\WINDOWS
DirectX Version: 10.1
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Notes
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
Display Devices
Card name: ATI Radeon HD 4550
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x9540)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_9540&SUBSYS_00021028&REV_00
Display Memory: 4341 MB
Dedicated Memory: 501 MB
Shared Memory: 3840 MB
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor Name: ACER X193W
Monitor Model: P193W
Monitor Id: ACR000C
Native Mode: 1440 x 900(p) (59.887Hz)
Output Type: HD15
Driver Name: aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atiumdag,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1129 (English)
Driver Version: 8.970.100.9001
DDI Version: 10.1
Feature Levels: 10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.1
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Attributes: Final Retail
Driver Date/Size: 13-Jan-15 12:00:00 AM, 1094024 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-D600-11CF-F177-0820BEC2C535}
Vendor ID: 0x1002
Device ID: 0x9540
SubSys ID: 0x00021028
Revision ID: 0x0000
Driver Strong Name: oem6.inf:cb0ae4148d6fe4d7:ati2mtag_R7X:8.970.100.9001😛ci\ven_1002&dev_9540
Rank Of Driver: 00D72001
Video Accel: ModeMPEG2_A ModeMPEG2_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeVC1_VLD
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
Current Mode: 1360 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SONY TV
Monitor Id: SNY5803
Native Mode: 1360 x 768(p) (60.015Hz)
Output Type: Displayport External
DDI Version: 10.1
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x1002
Device ID: 0x9540
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (2- High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0269&SUBSYS_102802DA&REV_1001
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 10.00.10586.0000 (English)
WHQL Logo'd: Yes
Date and Size: 29-Oct-15 12:00:00 AM, 404480 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
System Devices
Device ID: PCI\VEN_8086&DEV_0041&SUBSYS_02DA1028&REV_02\3&172E68DD&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:23, 330080 bytes
Device ID: PCI\VEN_8086&DEV_3B4A&SUBSYS_02DA1028&REV_05\3&172E68DD&0&E4
Name: ATI Radeon HD 4550
Device ID: PCI\VEN_1002&DEV_9540&SUBSYS_00021028&REV_00\4&1165B574&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\atikmdag.sys, 8.01.0001.1248 (English), 1/13/2015 17:41:40, 11922944 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0024 (English), 1/13/2015 16:20:14, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atikmpag.sys, 8.14.0001.6264 (English), 1/13/2015 16:20:44, 359936 bytes
Driver: C:\WINDOWS\system32\atiumd64.dll, 7.14.0010.0911 (English), 1/13/2015 17:45:22, 7540288 bytes
Driver: C:\WINDOWS\system32\atiumd6a.dll, 8.14.0010.0359 (English), 1/13/2015 17:45:26, 4292192 bytes
Driver: C:\WINDOWS\system32\atitmm64.dll, 6.14.0011.0023 (English), 1/13/2015 16:40:34, 120320 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 3/6/2012 17:59:32, 618823 bytes
Driver: C:\WINDOWS\system32\amdpcom64.dll, 8.14.0010.0023 (English), 1/13/2015 17:47:02, 62464 bytes
Driver: C:\WINDOWS\system32\atimpc64.dll, 8.14.0010.0023 (English), 1/13/2015 17:47:02, 62464 bytes
Driver: C:\WINDOWS\system32\atiadlxx.dll, 6.14.0010.1104 (English), 1/13/2015 16:20:58, 535552 bytes
Driver: C:\WINDOWS\system32\atiumd6a.cap, 1/13/2015 16:25:00, 2818784 bytes
Driver: C:\WINDOWS\system32\atimuixx.dll, 6.14.0010.1002 (English), 1/13/2015 16:40:30, 21504 bytes
Driver: C:\WINDOWS\system32\atiapfxx.exe, 6.14.0010.1001 (English), 1/13/2015 16:42:54, 159744 bytes
Driver: C:\WINDOWS\system32\atiumd6v.dll, 7.14.0010.0184 (English), 1/13/2015 17:46:44, 1065720 bytes
Driver: C:\WINDOWS\system32\ativvsva.dat, 1/13/2015 16:25:00, 157144 bytes
Driver: C:\WINDOWS\system32\ativvsvl.dat, 1/13/2015 16:25:00, 204952 bytes
Driver: C:\WINDOWS\system32\atiesrxx.exe, 6.14.0011.1122 (English), 1/13/2015 16:41:00, 238080 bytes
Driver: C:\WINDOWS\system32\atieclxx.exe, 6.14.0011.1122 (English), 1/13/2015 16:41:14, 514048 bytes
Driver: C:\WINDOWS\system32\atiedu64.dll, 6.14.0010.2514 (English), 1/13/2015 16:40:28, 59392 bytes
Driver: C:\WINDOWS\system32\ATIDEMGX.dll, 2.00.5491.21036 (English), 1/13/2015 16:41:14, 442368 bytes
Driver: C:\WINDOWS\system32\atio6axx.dll, 6.14.0010.11672 (English), 1/13/2015 16:46:26, 26017280 bytes
Driver: C:\WINDOWS\system32\aticaldd64.dll, 6.14.0010.1734 (English), 1/13/2015 16:26:32, 15827456 bytes
Driver: C:\WINDOWS\system32\aticalrt64.dll, 6.14.0010.1734 (English), 1/13/2015 16:26:40, 51200 bytes
Driver: C:\WINDOWS\system32\aticalcl64.dll, 6.14.0010.1734 (English), 1/13/2015 16:26:38, 44544 bytes
Driver: C:\WINDOWS\system32\atipblag.dat, 9/12/2011 22:06:18, 3917 bytes
Driver: C:\WINDOWS\system32\atiu9p64.dll, 8.14.0001.6264 (English), 1/13/2015 17:46:00, 51152 bytes
Driver: C:\WINDOWS\system32\atiuxp64.dll, 8.14.0001.6264 (English), 1/13/2015 17:46:36, 61464 bytes
Driver: C:\WINDOWS\system32\atig6pxx.dll, 8.14.0001.6264 (English), 1/13/2015 16:20:52, 17920 bytes
Driver: C:\WINDOWS\system32\atig6txx.dll, 8.14.0001.6264 (English), 1/13/2015 16:20:50, 41984 bytes
Driver: C:\WINDOWS\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 21:35:30, 118784 bytes
Driver: C:\WINDOWS\system32\amdverag.dll, 1.421.0167.0773 (English), 1/13/2015 16:49:36, 53248 bytes
Driver: C:\WINDOWS\system32\ativvsnl.dat, 1/13/2015 16:25:00, 26936 bytes
Driver: C:\WINDOWS\system32\ativvsny.dat, 1/13/2015 16:25:00, 25 bytes
Driver: C:\WINDOWS\system32\atiapfxx.blb, 1/13/2015 16:42:54, 245952 bytes
Driver: C:\WINDOWS\system32\atidxx64.dll, 8.17.0010.0436 (English), 1/13/2015 17:45:48, 7569128 bytes
Driver: C:\WINDOWS\SysWOW64\atiumdag.dll, 7.14.0010.0911 (English), 1/13/2015 17:45:32, 6282616 bytes
Driver: C:\WINDOWS\SysWOW64\atiumdva.dll, 8.14.0010.0359 (English), 1/13/2015 17:45:38, 4782960 bytes
Driver: C:\WINDOWS\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 1/13/2015 17:46:56, 62976 bytes
Driver: C:\WINDOWS\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 1/13/2015 17:46:56, 62976 bytes
Driver: C:\WINDOWS\SysWOW64\atiadlxy.dll, 6.14.0010.1104 (English), 1/13/2015 16:20:56, 364544 bytes
Driver: C:\WINDOWS\SysWOW64\atiumdva.cap, 1/13/2015 16:22:32, 2852480 bytes
Driver: C:\WINDOWS\SysWOW64\atiumdmv.dll, 7.14.0010.0184 (English), 1/13/2015 17:46:42, 1978240 bytes
Driver: C:\WINDOWS\SysWOW64\ativvsva.dat, 1/13/2015 16:25:00, 157144 bytes
Driver: C:\WINDOWS\SysWOW64\ativvsvl.dat, 1/13/2015 16:25:00, 204952 bytes
Driver: C:\WINDOWS\SysWOW64\ati2edxx.dll, 6.14.0010.2514 (English), 1/13/2015 16:40:28, 43520 bytes
Driver: C:\WINDOWS\SysWOW64\atioglxx.dll, 6.14.0010.11672 (English), 1/13/2015 16:39:54, 19584512 bytes
Driver: C:\WINDOWS\SysWOW64\atidxx32.dll, 8.17.0010.0436 (English), 1/13/2015 17:45:46, 6853272 bytes
Driver: C:\WINDOWS\SysWOW64\aticaldd.dll, 6.14.0010.1734 (English), 1/13/2015 16:24:46, 13402112 bytes
Driver: C:\WINDOWS\SysWOW64\aticalrt.dll, 6.14.0010.1734 (English), 1/13/2015 16:26:40, 46080 bytes
Driver: C:\WINDOWS\SysWOW64\aticalcl.dll, 6.14.0010.1734 (English), 1/13/2015 16:26:36, 44544 bytes
Driver: C:\WINDOWS\SysWOW64\atipblag.dat, 9/12/2011 22:06:18, 3917 bytes
Driver: C:\WINDOWS\SysWOW64\atiu9pag.dll, 8.14.0001.6264 (English), 1/13/2015 17:45:58, 38768 bytes
Driver: C:\WINDOWS\SysWOW64\atiuxpag.dll, 8.14.0001.6264 (English), 1/13/2015 17:46:34, 48544 bytes
Driver: C:\WINDOWS\SysWOW64\atigktxx.dll, 8.14.0001.6264 (English), 1/13/2015 16:20:46, 33280 bytes
Driver: C:\WINDOWS\SysWOW64\atiglpxx.dll, 8.14.0001.6264 (English), 1/13/2015 16:20:50, 14848 bytes
Driver: C:\WINDOWS\SysWOW64\ativvsnl.dat, 1/13/2015 16:25:00, 26936 bytes
Driver: C:\WINDOWS\SysWOW64\ativvsny.dat, 1/13/2015 16:25:00, 25 bytes
Driver: C:\WINDOWS\SysWOW64\atiapfxx.blb, 1/13/2015 16:42:54, 245952 bytes
Driver: C:\WINDOWS\atiogl.xml, 3/28/2012 22:45:34, 38177 bytes
Driver: C:\WINDOWS\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 6/22/2009 15:34:36, 51200 bytes
Driver: C:\WINDOWS\system32\ATIODE.exe, 1.00.0000.0001 (English), 8/27/2010 18:33:08, 332800 bytes
Driver: C:\WINDOWS\system32\atiglpxx.dll, 8.14.0001.6264 (English), 1/13/2015 16:20:50, 14848 bytes
Driver: C:\WINDOWS\system32\aticfx64.dll, 8.17.0010.1129 (English), 1/13/2015 17:45:56, 1094024 bytes
Driver: C:\WINDOWS\SysWOW64\aticfx32.dll, 8.17.0010.1129 (English), 1/13/2015 17:45:54, 929736 bytes
Driver: C:\WINDOWS\system32\coinst_8.97.100.9001.dll, 1.00.0004.0005 (English), 1/13/2015 16:33:12, 69632 bytes
Name: Intel(R) 82578DM Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_10EF&SUBSYS_02DA1028&REV_05\3&172E68DD&0&C8
Driver: C:\WINDOWS\system32\DRIVERS\e1k63x64.sys, 12.01.0077.0000 (English), 2/20/2013 19:02:06, 498032 bytes
Driver: C:\WINDOWS\system32\e1k63x64.din, 2/20/2013 19:02:06, 3093 bytes
Driver: C:\WINDOWS\system32\NicCo36.dll, 2.01.0002.0000 (English), 2/20/2013 19:02:06, 36472 bytes
Driver: C:\WINDOWS\system32\NicInstK.dll, 9.10.0083.0000 (English), 2/20/2013 19:02:06, 100736 bytes
Driver: C:\WINDOWS\system32\e1kmsg.dll, 10.00.0123.0000 (English), 2/20/2013 19:02:06, 73064 bytes
Name: Virtualization Engine Controller
Device ID: PCI\VEN_8086&DEV_3B30&SUBSYS_02DA1028&REV_05\3&172E68DD&0&FB
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
Device ID: PCI\VEN_8086&DEV_3B3C&SUBSYS_02DA1028&REV_05\3&172E68DD&0&D0
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:23, 95584 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:23, 454496 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:23, 500064 bytes
Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_3B22&SUBSYS_02DA1028&REV_05\3&172E68DD&0&FA
Driver: C:\WINDOWS\system32\DRIVERS\storahci.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:23, 133984 bytes
Device ID: PCI\VEN_8086&DEV_3B42&SUBSYS_02DA1028&REV_05\3&172E68DD&0&E0
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_3B56&SUBSYS_02DA1028&REV_05\3&172E68DD&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:18, 79872 bytes
Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:19, 97280 bytes
Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:19, 333824 bytes
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_02DA1028&REV_A5\3&172E68DD&0&F0
Name: Memory Controller
Device ID: PCI\VEN_8086&DEV_0040&SUBSYS_02DA1028&REV_02\3&172E68DD&0&00
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
Device ID: PCI\VEN_8086&DEV_3B34&SUBSYS_02DA1028&REV_05\3&172E68DD&0&E8
Name: LPC Controller
Device ID: PCI\VEN_8086&DEV_3B0A&SUBSYS_02DA1028&REV_05\3&172E68DD&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.10586.0000 (English), 10/30/2015 07:17:23, 18784 bytes
Regarding audio over the Display Port output, I think you won't be able to do it with Windows 10. According to AMD's website, the only driver support they have (and might ever have) for their HD 4xxx series, is the current generic video driver you can get over windows update.
You can either get a dedicated video card that is supported (and hopefully has HDMI so you can stop using an adapter), or get the sound to the TV over a miniplug (3.5mm) aux cable to the TV's input (if it has one at all). Other than that, there's nothing you can do. I still cannot confirm if your computer can output sound over DisplayPort, but it's as unlikely as AMD releasing a new driver that gives you back functionality with W10.
