[SOLVED] missing cable for MSI Radeon RX 570 DirectX 12 RX 570 ARMOR MK2 8G OC to PSU
Nov 11, 2018
just got my MSI Radeon RX 570 DirectX 12 RX 570 ARMOR MK2 8G OC In the mail today, unboxxed it and installed it on my mobo. when I discovered Im missing a power cable that goes from the card to the power supply. I've looked around for a very long time trying to find a matching cable, looking on other threads, and even asked some friends for help, and will continue to do so unless yall can help me. any help is appreciated.
heres the card I bought https://www.newegg.com/Product/Product.aspx?Item=N82E16814137291&Description=RADEON%20RX%20570%20ARMOR%20MK2%208G%20OC&cm_re=RADEON_RX_570_ARMOR_MK2_8G_OC-_-14-137-291-_-Product
Heres my power supply https://www.newegg.com/Product/Product.aspx?Item=N82E16817139112&Description=corsair%20cx750m&cm_re=corsair_cx750m-_-17-139-112-_-Product
have you guys had any problems similar?
You have a semi-modular PSU. You should have at least 1x8-pin PCIe power cable that isn't modular. I can actually see it in the picture and it is connected to the PSU. You can run that GPU with just a single 8-pin. Any extra cables would have come in the PSU box.
