Hello All,
Sorry to be cross posting this. I hoping some of the Gigabyte gurus here might have an answer. Thanks.
I just got a new Gigabyte GA-P35-DS3L P35+ICH9, and I'm putting together system as part of whole new build with all new components. I'm at the point where I want to backup the install, and here is where I ran into a problem.
I'm using Ghost(9.0/2003) but the the ghost CD-ROM bootdisk boots just fine, but when it comes to loading the OAKCDROM.SYS driver, the driver loads fine, but here is strange one, it can't find the IDE optical drive, the Liteon DVD-RW that is has been happily booting off of and loading all those nice drivers (ASPI, ATAPI, etc. etc.). This ghost boot disk is a trusted and true disk that works fine my AMD based Shuttle XPC, as well as the old P4 Dell at my work. At the moment I can work around it using a USB flash drive, but since this is a build for a friend, I'd rather be able create a set of backup DVDs. Without proper detection of the drive, MSCDEX is shot and I can't get to the .gho ghost image files.
Has something changed with the these new P35+ICH9 chipsets? Or should I suspect the Liteon DVD-RW drive? I'll be sticking in a old CD-ROM drive to see that is the case. Or is it and incompatibility with the old OAKCDROM.SYS and that I should use something more modern?
Thanks.
P.S. Quick update. I've tried a different CD-ROM drive and it still encounters the same problem.
Thanks.
