If it helps I have the b360m-a prime motherboardI have the razor Lian li case and its my first build. I’m really confused as to why I can only see one front panel connecter. I just have the “power sw” one I don’t see the rest. Is it supposed to be like this or did the manufacturer mess up. Thanks in advance.
I tried that the only cable I see coming from there is power switch, is it possible that I don’t need the rest of themJust follow the cables from where they are attached to the front panel audio and USB jacks. The other end of them will be taped up there somewhere.
