Hi, i got a white set of cablemod pro cables but it doens t come whit a sata power cable which i need for the aio pump, is it ok to use the cablemod cables and just use the sata cable that came with corsair hx1000?
AS long as all cables are made to work with specifically PSU model you have there is no problem with mixing cables. However do not use cables from different model as those may be not compatible.
