Sorry if this has been asked before, just have a quick question regarding custom sleeved cables.
If I've previously been using a set of sleeved cables from cablemod with my EVGA power supply and want to replace a few of the cables (namely the atx and pcie cables) with custom sleeved cables from a local supplier to add a bit of colour to the setup. Am I likely to encounter any issues mixing cables from different sources / manufacturers together? Does it matter if I use an 8 pin pcie header instead of 6+2 header this time or do I need to worry about anything other than making sure they're compatible with the PSU? i.e. pin layout, awg 16 wire etc.
Thanks for the help!
