mixing differnt voltage batteries?
computers4life
12
I know this isn't probably the best place to ask but i love the community here so here goes.
these are rechargable NiMH batteries.
I want to take 16 rechargeable AA batteries from the same manufacture. they are 3100 mAh at 1.2 V. I want to set 8 of them in series and 8 of them in parallel, giving one set at 9.6 V @ 3100 mAh and the other set at 1.2 V @ 24,800 mAh. i want to then run them in parallel hoping to give me 9.6 V @ 27,900 mAh. My question will this work or will i need to put some diodes or something in front of the high amp one to keep the high volt one from trying to charge it and damage it and will the diodes or whatever i use mess with the amps or volts or anything like that. My other question is will it be that amps at that voltage or will it be 9.6 V and 24800 or will this system not work at all and is there anything special i have to do to make it work?
Also can 9.6 V power a 12 V amp without much issue?
I'm not trying to run a car and acid wont work. I'm trying to make a system of mine portable, i could always use D batteries but they are a bit big but i guess i will go with that unless you have a better option
For 9.6V from 1.2V batteries, 8 x 1.2 = 9.6V
So with 16 batteries, I'd put make 2 lots of batteries in series - 8 batteries each. Then I'd put those two lots together in parallel.
+battery-+battery-+battery-+ ....battery- - 8 of them in series
two lots
+battery-+battery-+battery-+ ....battery- - 8 of them in series (=9.6v)
< 9.6v |
Do you know how much power you need out of them? Do you have a multimeter to measure the current you're using?
Also, does whatever you're driving have a low-voltage cutoff? Do you know where it's set?
Other option is a LiPo (or a couple in parallel), like this: http://www.hobbyking.com/hobbyking/store/__15521__Turnigy_5000mAh_4S1P_14_8v_20C_Hardcase_Pack.html
