For the last couple of years I've been running 3 screens off my 980ti 1 x 4K and 2 x 1080p all that time the 4K has always misbehaved quite a lot, typically when i boot the system up the 4K will have a massive delay (upto 10-15 minutes) before it comes on, sometime I even need to turn it on and off again manually, and then sometimes even that doesn't work and I need to reboot the machine.
Typically once it's up and running everything is fine, sometime when I'm gaming or watching films on the 4K I occasionally start to get intermittent drops (i.e. screen goes black from a couple of seconds), but, turning it off and on again seems to stop it.
It has obviously been bugging the crap out of me, but having checked all the cables and tried swapping each screen on each graphics port, it probably leaves a more serious hardware issue, but not knowing what it is I'm reluctant to start throwing money at it, if I'm not sure it will solve the problem.
But, just now I had to reboot 3 times to get up and running again, so enough is enough I need to do something about it.
So my questions are:
1. by running a 4K and 2 x 1080p's off a single 980ti am I overloading the card?
2. Do you think the card could be faulty? Or is it more likely the 4K?
3. I've got a 560ti in another machine I could use, I know I can't run it in SLI, but even though it doesn't match would I benefit from running the two smaller screen off it and letting the 980ti run the 4K solo?
Cheers
Cheers
