I am a beginner with PC building and liquid cooling. I am currently looking for parts to build a gaming PC, and I think I have found them, but I am worried about Galvanic Corrosion. The parts I have are Copper, Brass, Silver, and Nickel. These are my questions. 1.Will there be any problem with Corrosion? 2.Should I get an anti corrosive? 3.Would a silver kill coil do anything if I already have silver components in my loop? 4. Does an anti corrosive even work?
The parts I am using are a
Copper/brass core radiator
Silver fittings
Copper CPU waterblock
Nickel GPU waterblock
Silver Valve
Brass T-pipe
I will be using the PT-Nuke biocide, distilled water, and Mayhems Blue Dye.
Thank you in advance to anyone who responds.
Silver fittings
Silver Valve
Brass T-pipe
