Mixing metals + Pre-mixed coolant in water-cooling loop
Bounti
118
Hello! I have a question regarding the different blocks and the coolant I'll be using in my build. The first question is whether the following blocks will cause any issues at all in terms of compatibility.
Koolance CPU-380I Waterblock
http://koolance.com/cpu-380i-processor-water-block
Alphacool UT60 280mm Radiator
http://www.alphacool.com/product_info.php/info/p984_Alphacool-NexXxoS-UT60-Full-Copper-280mm.html
Alphacool XT45 360mm Radiator
http://www.alphacool.com/product_info.php/info/p973_Alphacool-NexXxoS-XT45-Full-Copper-360mm.html
EVGA GTX 780ti Classified Hydrocopper
http://www.evga.com/Products/Product.aspx?pn=400-CU-G788-B1
Secondly, I'm a little concerned about the coolant I'll be using in the loop. Initially, I was going for distilled water and a silver coil, but after reading Koolance's warranty that warns against mixing nickel and silver, I have reconsidered. The decision gets trickier when the color of the tubing or coolant must match my Asus Z87 Pro brown/and or gold color scheme.
Here it is:
http://assets.vr-zone.net/20189/Z87-PRO.jpg
It's between finding tubing that matches this theme + using distilled water and a silver coil
V S.
Getting clear tubing and using a pre-mixed gold colored coolant.
Thank you so much for taking the time to help me out!
