My PC Spec is like this
Cpu : Ryzen 5 1600 OCed to 3800 MHz
MB : MSI B350 Tomahawk
At first i only have the 2x4 GB T-Force Team Dark Grey DDR4 3000 with timing 16-18-18-38. Used it for 1 year with 2933 Speed XMP in the Mobo
And i got another stick of Corsair DDR4 Vengeance LPX PC25600 16GB (2X8GB) - CMK16GX4M2B3200C16 with timing 16.-18-18-36.
I thought if i mixed them i will got 24 GB Ram with 2933 speed and timing of 16-18-18-38, because i read in forums mixing different ram timing and speed will success but the higher speed ram will follow the slower ram speed and timing.
At first i reset my bios, insert the LPX and set via XMP to 3200 speed, then after it boot, i shut down, put my Team Dark Ram and it won't boot so i reset the bios again and i enable the XMP again to 3200 MHz with 4 stick inserted. I thought it won't boot because i not yet set manual timing for the RAMs.
But it boot successfully. I check the BIOS, HWInfo and CPU-Z it's actually running 3200 Mhz
I run some Benchmark like Cinebench. SuperPI. No BSOD yet.
Is the CPUZ and HWInfo not accurate or it just list my LPX speed? Or Maybe my Team Dark RAM is automatically overclocked to 3200 MHZ too? But the timing should be different then the LPX right?
Screenshoots :
Ram Speed
Ram Speed 2
Screenshoots :
Ram Speed
Ram Speed 2
