Question mixing ram with prebuilt. help
Apr 3, 2019
got a prebuilt gaming pc for christmas, and I've been extremely satisfied with it. Every game I play I run fine except Rust. probably because some of my ram is rerouted so i only have like 5.9gbs usable and my motherboard doesnt let me reroute ram or overclock. so I ordered a new 1x8 stick of ram since I knew it'd fix my freezing on rust. so i found a stick of ram that had the same speed since that was the only thing I knew about my ram, so i ordered this stick of ram and was wondering will it be compatible. i cant really afford two sticks of ram so i have to criss cross ram if this isnt compatible would you know one that is
the ram:
https://www.newegg.com/Product/Product.aspx?Item=20-232-086&Ignorebbr=true
my pc:
https://www.walmart.com/ip/HP-Pavil...hguid=c28ea0f3-775-169e44bd27d345&athena=true
specs:
AMD Ryzen 5 2400g proccesor
ddr4 2666mhz sdram (1x8)
AMD Raedon RX 580 with 4gbs of GDDR5 dedicated memory
