MMM help
pratkal
50
My system config is
amd x4 955BE
asus m3a78-em
4GB ddr2 ram
XFX HD 5850 1GB
Corsair 550VX
k my problem is that since last night the 4th core is not going in idle mood
Few days back when i was used to check my cpu due to over heating http://www.tomshardware.com/forum/279780-28-955be information here my cpu was used to stay @ 800 MHZ @ idle but now my cpu stays @ 3.2GHZ and even if it does go low only the first 2 core goes @ 800MHZ these is heppening since last night
please remeber i have not OC my cpu and please help me as its scaring me @ 0p cpu usage 3rd and 4th core always stay @ 3,2GHZ though 3rd core goes to 2GHZ some times but 4th always 3.2GHZ
any idea what is going wrong?
the cpu usage is also low the problem is not there cpu is not going to slow down all the 4 core ( 3rd and 4th most of the time ) actuly there is no performance drop either even in fact i got higher i got 500 more score in futuremark vantage for cpu though the thing is scaring me that now in idle temp is hitting 52 which is not nice @ all
few days back all the 4 core used to stat @ 806 MHZ in idle and was never touching 3.2GHZ when used like shown in screen
but @ moment those are rarely going below 3.2GHZ
and more worst thing scaring me is Voltage drops while speed dont
anyways found the solution......
if some 1 else looking for the solution here the trick
Go to Control Panel\All Control Panel Items\Performance Information and Tools
click on power management / adjust power setting
and chose either Balanced or Power Saving mode
