Hello there, I have two mobile 4G LTE routers from Huawei older E5377T and slightly newer E5577Cs. Both operate by T-Mobile provider and are limited to 60mbps bandwidth but have unlimited transfer.
I'm more or less happy with E5577Cs I use as a backup and on the go source of internet. My old man on the other hand started nagging at E5377T, mainly because he now uses much more frequently and more types of streaming services.
My first thought was that we should talk with the operator about increasing the bandwidth, however when I ran some tests in various places the most I got on both was around 40 mbps and lowest 10 mbps. So now instead of increasing the bandwidth I gyrate around idea of signal boosting.
Do yall think adding some mobile antenna to each through available ts9 ports is worth even trying?
I dug a little on the topic and had almost only negative reviews of small portable ones (cb radio style or smaller or cheap looking plastic boxes). Most people advise decent directional antenna but I want to keep using these routers as mobile routers so that's kind of out of the question. Is what I assume middle ground like NETGEAR 6000451 omnipositional antenna worth a shot?
If not then maybe purchasing a newer devices would be more beneficial? Will buying for example newer Huawei E5785 possibly improve anything or I should aim higher to actually see some results?
