alright, just a few questions on mobo connections with case and power supply.
~the 2 fans in my case have a 3 pin connector, and then a adapter on them that has 2 4 pin "legacy" power connectors, i notice that there are 2- 3 pin fan connectors on my mobo, so i just took off the adapters and used the 3 pin to connect each fan to the mobo, is this fine? whats the use of having the adapters? (i have a coolermaster mystique case, and a intel p965lt mobo, antec true power trio 650w psu)
~does it matter which of the sata ports i plug my hdd into?
~i got a wd raptor, and it came with a sata cable that on the hdd end, has a long connector a bout 2 to 3 inchs long, that include the sata port and something else, im assuming its a molex power connector as well, right now i have it connected using just a regular sata cable and a 4 pin "legacy" power plug, my psu cables do have the other slot which im assuming is molex, which looks like a elongated sata port, labeled as sata, should i keep with my current setup or switch to the "molex" or whatever it is.
thanks
thanks
