Question Mobo CPU problem prt 2
Jul 3, 2019
6
Hey guys. I'm trying to build using an aorus b450 mobo and a ryzen 2700x inside a dell inspiron gaming 7450 case and the psu which delivers 600 volts. The problem is that it won't boot. the mobo is saying that there is a problem with the cpu as the status light is red. Plz give suggestions!
I hope it's not 600 volts as that would smoke everything including owner it should be Watts. Are you sure PSU has all right connections because some brand name computers may have different ones ? Brand name computers may also have different MB mounts so there could be a short somewhere. I would try to breadboard it, assemble just main elements outside of the case.
Yeah sorry, 600watts. I've triple checked all connections. Also checked out the site suggested above but hasn't helped. I'll definitely try breadboarding it though, thanks. But just in case it still doesn't work any other suggestions?
