MOBO green light on, red light not blinking, no beeps but processor fan working, no display
mohithvemula
I had bought a new NVIDIA GeForce 210 GPU for my MOBO
I played for a while and decided to change my cpu's place
After that, a blue screen appeared and comp stopped working, but after a while, i could switch the comp on again.
THis happened several times after my comp completely stopped working, dosent show any display signal but green light on motherboard and the fan works. EVen the red light is not blinking and no beeps.
How can you resolve this problem???
(I tried reinsrting ram and replugged all the cables and resetted BIOS, but still comp dosent work)
Can you explain what you mean by "change my CPU's place?" You can't move the CPU. Where would it go?
Do you mean that you put the GPU, the graphics card, in a different slot?
The first test I always suggest is to put back the old graphics card (or fall back to onboard graphics) and see if it works again.
Change My CPUs Place in the sense.......
I actually have a very old table for my computer. I used to keep it open lying on the top of the table, but then I unplugged all the cables and had kept it in a cupboard below so that the surface of the table is free. Then I connected all the cables back and closed the cupboard's door.
After that the computer had shut down with a blue screen while I was playing Minecraft. When I opened the door, the air inside was damn hot. So I thought that it was a shut down caused by overheating
So I again assembled the computer on the surface of the table in open air so that it does not overheat
I played again and experienced several shut downs with a blue screen until my computer stopped working again
By the way,
I have only one PCIe slot
Intel Core 2 Duo @ 3.30GHz
Only two slots for RAM, both with each 2gb DDR2
500 TB HDD
Some INTEL motherboard
Only one fan for cooling
There was no graphics card before and no Integrated Graphics also
