Mobo + intel cpu bundle with 200$ max
live4u
Folks
I have a old gigabyte+core2duo combo and I love every bit of it. The only problem is I have DDR2 4GB and missed out upgrading it to 8Gb (have only 2 slots). DDr2 being super expensive, I thought I will move to newer gen 4 cpus and mobo bundles. Can you suggest a combo (need website address also) that can do justice? Gigabyte gets higher priority but is not the only choice. I can do i3,i5,i7. Requirement is, 4 memory slots is a mandatory one. Higher speeds of memory is good
Appreciate your help.
Thanks
Live
Thanks for responding.
How about i3 - 99$ - http://www.newegg.com/Product/Product.aspx?Item=19-116-995 ?
BTW, I dont know the difference between g3258 and i3. The onlything I see is G is pentium and i3 is core :) Also,
Hearing ASRock first time. Is that good or equivalent or betterthan any Gigabytes? Pardon me for my ignorance
