[SOLVED] Mobo left side to right side
Jun 16, 2019
64
My current mobo joshua h61 uatx is on the left side of case, new case i ordered has window on the left side, do i just flip the mobo around and put it on the right side?
Jan 11, 2014
404
8
10,865
44
If the back panel I/O shield works then it posibble to do a flip but some cases (Pre-Built for Example) not work like that. Because their mount positions. If the mounts work fine and you have plenty of space inside the case for other components then it will be fine. and your motherboad will not puke doing that flip XD.
