mobo memory help
Joan Albert
67
Hello, can someone please tell me if this memory: Gskill aegis 4Gb pc3-1600/1666 DDR3 1333Hz 1,5V cl9 would be compatible with an HP PRO 3010 microtower pc which has this mobo: PEGATRON CORPORATION 2A94h
pc specs: http://www.cnet.com/products/hp-pro-3010-core-2-duo-e7500-2-93-ghz-monitor-none-series/specs/
mobo specs: http://www.findlaptopdriver.com/pegatron-2a94h-motherboard-specs-3272011h24/
i installed the memory and the pc won't start, it beeps.
Maximum RAM support:
4 x 240-pin DDR3 DIMM slots Supports Dual Channel DDR3 1066/800 MHz non-ECC , un-buffered memory (Max 8GB)
If you can edit the speed in the bios it may work but its unlikely
