C ChrisTsall99 Distinguished Sep 17, 2015 702 0 18,990 Apr 11, 2016 #1 Hello... So i have 2 options : GA-H110M-S2H or Asus H110M-A Which mobo ia better
Solution Tradesman1 Apr 11, 2016 Yep, pretty much a toss, either/or should do well 😉 Think the GB runs about $10 less
F Fazal786 Commendable Apr 11, 2016 5 0 1,510 Apr 11, 2016 #2 I am not an expert but I would suggest you to go for DDR4 Ram supporting mobo. I am currently building a budget PC too and I would have gone with GA-H110M-S2H but we don't have it her in India. Sad. 🙁 Upvote 0 Downvote
BadActor Expert Ambassador Oct 31, 2015 8,749 1 54,965 Apr 11, 2016 #3 Between those two, I would go with the lowest price. They should be fairly equal in terms of quality and features. Upvote 0 Downvote
Tradesman1 Legenda in Aeternum Jun 5, 2013 67,881 41 126,960 Apr 11, 2016 Solution #4 Yep, pretty much a toss, either/or should do well 😉 Think the GB runs about $10 less Upvote 0 Downvote Solution
S Super_ Reputable Sep 26, 2015 192 0 4,690 Apr 22, 2016 #5 I would pick the asus because asus is more reliable than anyone but either one is good. Upvote 0 Downvote
