Mobo problem help :(?
Denis_43
97
Hello i started Cabal 2 then while i play 1hour my PC shut down and when i try to start it he power for 1 sec and shuts
I tryed to pull out the 24 pin connector and place it again
My Pc powered off when i moved the connector then i tryed more and it powered i moved it again and the pc didnt shut down ?
What may the problem is and hpw can be fixed?
1| Can you please pass on your full system's specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
If this is a prebuilt system, please pass on an SKU/make and model or a link.
2| If the system shuts down when under a load scenario, it's tell tale that the PSU is giving up on it's duties. If that is true then the PSU will need replacing.
