I have a new z87x mobo, aside from the noew i/o panel with foam that makes it hard to fit the mobo itself. I have a million screws and no washers, none of the screws are labeled and im not sure which ones to use to mount it in my case.
What should i do?
Some are really small and dont really fit, others are too big where the mobo would shake. None are perfect
What should i do?
