D Dann1ck Honorable Aug 7, 2013 123 0 10,680 May 25, 2014 #1 Any good mobo with z77 chip or better and 1155 socket in the 100$ price range? NOT ASROCK they are the reason why i need to change my mobo
Solution S S Suztera May 25, 2014 Well here is a list of options but you will need to increase your budget: http://ca.pcpartpicker.com/parts/motherboard/#l=2,3,4&c=52&sort=a7 Cheapest new is this: http://ca.pcpartpicker.com/part/asus-motherboard-p8z77vlk Or you can have a look at used parts. EDIT: Change to Canadian version
S Suztera Polypheme Mar 18, 2014 12,729 0 60,960 May 25, 2014 Solution #2 Well here is a list of options but you will need to increase your budget: http://ca.pcpartpicker.com/parts/motherboard/#l=2,3,4&c=52&sort=a7 Cheapest new is this: http://ca.pcpartpicker.com/part/asus-motherboard-p8z77vlk Or you can have a look at used parts. EDIT: Change to Canadian version Upvote 0 Downvote Solution
