Question Mobo Swap - GPU now running louder and hotter ?
Dec 23, 2020
38
So I had purchased a prebuilt (Omen 30L) and had it for a bit but really wanted to swap the case seeing as it had only one intake and outtake fan that were covered by cables and just aesthetic design pieces.
So I moved everything over to a Meshify C case and everything was running really well, my GPU stayed cool under load, everything was fine, even with some cheap $17 3-pack fans I was running
Recently I decided to swap motherboards to a ASUS B-550F ROG STRIX board, as well as swapping my PSU to a 850w Corsair RMx instead of sticking w/ the 500w cooler Master one that originally came with it that was already starting to act up
I noticed that my GPU temps now hit a max of 82c. I decided to swap out my fans for noctua fans and put a VGA cooler under the card and it literally made no difference in temps.
My GPU runs pretty loud now too so I’m wondering if this is normal, is there a way to fix this? I’ve tried adjusting fan curves for the card and get it to 77c but it gets LOUD
Here’s the card (I pulled it from the prebuilt)
https://www.techpowerup.com/gpu-specs/hp-rtx-2060-oem.b8144
