ok!
STEP I : General Troubleshooting.
- I would temporarily strip mobo off any unnecessary components and leave it with bare minimum peripherals keyboard, mouse, graphic card (remove it if your mobo has an integrated video that you could use), single monitor,(disconnect all other CABLES or peripherals CD drives and all hard drive including system drive) (ideally remove mobo from the case
- I would double check every single connector for tightness PSU cables included ( PSU end for modular one) fans PCI-e mobo and CPU power
- Make sure CPU cooler Fan is connected to mobo dedicated CPU fan header and is functional (some mobos would refrain from booting otherwise if Fan not detected or defective).
- I would make sure RAM modules are compatible, Non defective and VGA are well seated ( would re-seat them for more assurance) (RAM slot seating order as per mobo manufacturer specs)
- I would make sure there are no potential metal or shorting objects or astray screws underneath laying around in the case.
- I would check PSU fan for spin ( depends on PSU), VGA and CPU fans as well and keep an eye on their behavior during the boot process.
STEP II: THE BIOS.
- Clear CMOS (jumper on your mobo :How to at page 30 of your mobo manual --->
http://download1.gigabyte.us/Files/Manual/mb_manual_ga-ep43t-usb3_e.pdf
- Your mobo has 3 BIOS features: (PAGE 66 of mobo manual )
1. Xpress Bios rescue >> automatically loads a back up bios that it hides on system drive when main Bios gets corrupted.
2. It has dual PHYSICAL bios: a main Bios and back up Bios which is configurable thrugh Bios interface and is loaded automatically if main one is damaged ( independent from hard drive availability) l>>>
https://www.gigabyte.com/microsite/121/tech_dualbios_setup.pdf
3. It supports Q-FLASH : allowing to Flash main Bios, update it from a flash Drive without going through the Bios interface through a keyboard shortcut , see here >>>
https://www.gigabyte.com/microsite/121/flashbios_qflash.pdf
During Bios Post your mobo Biios displays all these options and the keyboard keys to press .
Basically boot your system with bare minimum hardware, and do a Bios reset if needed.
