So I bought two Actiontec Bonded MoCA 2.0 Ethernet to Coax adapters and I connected one upstairs where my Verizon FIOS router is and another one down in the basement.
Upstairs I connected the coax from the wall into the splitter and then connected one coax to the FIOS router and one to the MoCA adapter. I then plugged the Ethernet cable from the adapter to the FIOS router.
Downstairs I just connected the cox from the wall directly to the MoCA adapter and then the Ethernet from the adapter to another FIOS router that I have downstairs.
The second FIOS router downstairs is the same Actiontec router as upstairs and I use it as a bridge.
Now everything works, but my speeds are exactly the same as when I didn't have the MoCA 2.0 adapters. I was hoping for speeds of around 80 to 100 MBs per second, but instead am stuck at 10 MBs per second.
What I am doing wrong? Why did the speed not increase? My house is new and the coax cabling should be fine.
I can't understand why I'm not getting closer to 1 gigabit rather than just 100 Mbps. Please help!
