Modded Minecraft Running at 12-40 fps on a great pc?
PCGaming247
66
First of my spec's
--My Rig--
OS----------Win 10 64bit Home
CPU--------Intel i7 6700k
Motherboard------Gigabyte z170x-Gaming 7
GPU---------GTX 1080 Gigabyte G1 Gaming
RAM--------G.SKILL Ripjaws V Series 64GB (4x16GB), 3333MHz
SSD--M.2------Samsung 950 PRO Series - 512GB PCIe NVMe
SSD-------------Samsung 850 EVO-Series - 500gb
HDD 1--------- 5TB Toshiba SATA 6.0GB/s 7200rpm
PSU--------------EVGA SuperNova 1000 P2
Cooling---------Corsair H115i Water/Liquid CPU Cooler 280mm
Case-------------Corsair Graphite Series 780T Full Tower PC Case - Black
Monitor---------LG 2K, 34" Class 21:9 UltraWide WFHD IPS LED (34UM57-P)
I have been having the hardist time getting my minecraft to run even close to as good as it runs on my server computer, and that thing keeps 60fps when the server is running and my kids are playing minecraft on it at the same time with sharders. Here is the specs for that pc.
--Server PC--
---------OS---------------------------
Win 10 64bit Home
--------CPU---------------------------
Intel i7 4790k (OCed 5.0)
--------Mother Board------------------
ASRock Z97 Extreme4
---------GPU 1 & 2-Main---------------
2x GTX 970, SLI, Gigabyte G1 Gaming
---------RAM--------------------------
Kingston Technology HyperX Beast Series 32GB (4x8GB), 1866MHz
---------SSD 1------------------------
500gb Samsung 850 EVO-Series
---------SSD 2------------------------
120gb Samsung 840 EVO-Series
---------HDD 1------------------------
2TB Hitachi Ultrastar 7K3000 Enterprise SATA 6.0GB/s 7200rpm
---------HDD 2------------------------
---------PSU--------------------------
EVGA SuperNova 1300 G2
---------Cooling----------------------
CORSAIR H110 Water/Liquid CPU Cooler 280mm
---------Case-------------------------
Corsair Graphite Series 780T Full Tower PC Case - White
---------Monitor----------
34" Class 21:9 UltraWide WFHD IPS LED Gaming Monitor 34UM57-P
I have the technic launcher running 16gb of ram to minecraft. I also set the heap in java settings to
-Xms16384m -Xmx16384m I just added the heap thing last night after months of trying to fix things in other ways "optifine, foam fix, better fps (mods), but nothing helps. Its unplayable at 12 fps. I feel I might have a hardware problem but nothing else I play or do shows any problem.
Any and all help would be great thanks...
Why would you suspect a hardware problem if it's only this game, and especially a game that's been modified.
This is probably a question for the Minecraft forums, though a good first step might be to go back to a Vanilla, clean install. Once you're there make any changes one at a time.
Even unmodded I don't get a solid 60 fps, as far as why I think it maybe hardware: I know this rig should be getting higher fps, when my server pc, with lower specks, runs the same pack, and the server at the same time and keep 60 fps. I saw a post about it could be do to java limitations but then the problem would be across the board on both computers as they both are running the same java with the same heap sizes also. An I didnt bring this to the minecraft forums because I bring all my tech questions here, I trust Toms have for years.
Again though, you said everything else appears to run fine. I can't grasp how that could possibly be a hardware issue. There are lots of reports of Minecraft performance issues though due to software problems.
The program may be unmodded now but that doesn't mean there isn't some underlying issue that requires you to remove and reinstall the game and other software.
I can't help any further though as I have no familiarity with Minecraft's issues.
let me try
i can't remember what causes it (something to do with 32 bit and 64). go into settings and check how much ram you are able to allocate. if its 1gb of ram you need to update your java to a 64 bit version.
i'll get back to you with a link
