The last time I posted, I was detailed and long-winded. I'll try to be more concise here in hopes of a response.
I've already tried replacing the modem and all wires, except for the coax which runs inside the house's walls.
Inside, my modem Upstream power is 57dB. Downstream is about -1.7dB and SNR is 43.5dB.
Outside, at the box connecting to the street, my Upstream is 44dB, Downstream is about 17dB and SNR 44.7dB.
Question: Does downstream power decrease when adding coax length to the run? Upstream definitely increases.
Question 2: Is the downstream power so high at the box, to give me a chance to have a good level by the time it reaches the modem?
Question 3: Is it (high downstream power) a problem that would not be fixed by simply adding more cable between it and the modem?
~Satou
~Satou
